Use this procedure to enable or disable the global FA Zero Touch Client Attachment feature on an FA Proxy or Server. By default, FA Zero Touch Client Attachment support is enabled.
Switch:1(config)# fa zero-touch-client standard camera i-sid 1003
Switch:1(config)# no fa zero-touch-client standard camera
Variable definitions
The following table defines parameters for the fa zero-touch-client standard command.
Variable |
Value |
camera |
Specify element type to match camera. |
phone |
Specify element type to match phone. |
router |
Specify element type to match router. |
security-device |
Specify element type to match security-device. |
srvr-endpt |
Specify element type to match srvr-endpt. |
switch |
Specify element type to match switch. |
video |
Specify element type to match video. |
virtual-switch |
Specify element type to match virtual-switch. |
wap-type1 |
Specify element type to match wap-type1. |
wap-type2 |
Specify element type to match wap-type2. |
